How to generate and load a program for Fairino robot
We are currently transferring a program created in RoboDK to a FAIRINO20 collaborative robot and conducting operational verification.
We have confirmed that the program runs correctly in automatic mode. However, when we attempt to move through the program point by point using manual (step-by-step) operation, a "null variable" error is displayed. As a result, we are unable to verify each point individually.
To help investigate the issue, I would like to send you the simulation data that we are using for the program transfer. Could you please review it and advise us on how to modify the program or settings so that step-by-step execution can be performed without the error?
Your guidance and support would be greatly appreciated.
[attachment=7834]
.rdk   上下A.B上と下の製品5本ずつ受け渡し Rrd Fr(本命) 5本状態 700B_RRARCH 吸着パッド2個.rdk (Size: 22.4 MB / Downloads: 101)
.rdk   310D QTR 上下A,B.rdk (Size: 34.65 MB / Downloads: 141)
Please try using the Fairino_db postprocessor.
Here is the explanatory video on how to use the generated program and points table: video
In addition, it is necessary to ensure that the robot dimensions (e.g., link lengths and offsets) accurately match those of the actual robot, as they may vary depending on the robot version.
Thank you for your information.
After reviewing the video, I would like to confirm a few points.
My understanding is that the robot in the video is operated automatically by importing a DB-format point table. Is this correct?
In addition, we previously received feedback from the Fairino robot manufacturer stating that importing and using a DB-format point table may be difficult, and that collaborative robots may require a Lua-format program rather than a DB-format file for reliable operation.
When using the Fairino_db post processor that you recommended, is it correct to understand that this is not an issue and that the robot can be operated properly using a DB-format point table?
Also, regarding your comment about robot dimensions, I understand that the robot parameters, such as link lengths and offsets, must accurately match the actual robot to avoid discrepancies between simulation and real-world operation.
Could you please provide more detailed step-by-step instructions on how to verify this? As a beginner, I would greatly appreciate a detailed explanation.
For example:
- How can I verify that the robot model in RoboDK matches the actual Fairino robot?
- Which specific parameters should be checked (link lengths, offsets, tool flange dimensions, etc.)?
- Where can I find these values in the Fairino controller, documentation, or robot specifications?
- How can I compare the values in RoboDK with those of the real robot?
- Is there a recommended calibration or validation procedure that should be performed before generating and running programs?
I would appreciate any guidance you can provide to help ensure that the simulation model and the real robot are configured correctly.
Thank you for your support, and I look forward to your response.
Could you kindly provide us with a document or procedure guide that outlines the method you explained for implementing the program?
Alternatively, if it is easier, we would greatly appreciate it if you could describe the necessary steps within this thread. If there are any existing materials, manuals, or reference documents that explain the process, we would be grateful if you could share them with us.
We sincerely apologize for any inconvenience this request may cause and greatly appreciate your assistance and support.
Thank you in advance for your cooperation.
Thank you for your questions. Please see my responses below:
Quote:1.  Is it correct that the robot in the video is operated automatically by importing a DB-format point table?
    Yes, that is correct.
Quote:2.  When using the Fairino_db post-processor that you recommended, is it correct to understand that this is not an issue and that the robot can be operated properly using a DB-format point table?
Quote:3.  How can I verify that the robot model in RoboDK matches the actual Fairino robot?
    You can compare the Cartesian coordinates of the flange zero point (also known as the null tool) for similar joint values. This is a good starting point for comparison.
Quote:4.  Which specific parameters should be checked (link lengths, offsets, tool flange dimensions, etc.)?
    You should check the DH parameters, specifically the link lengths and both angular and linear offsets.
Quote:5.  Where can I find these values in the Fairino controller, documentation, or robot specifications?
    Please check the official Fairino robot documentation and specifications.
Quote:6.  How can I compare the values in RoboDK with those of the real robot?
    You can compare the DH parameters in RoboDK (go to the Robot Control Tab -> Parameters) with the corresponding values from the documentation.
Please take a look at the following documentation also:
https://robodk.com/doc/en/General.html#Model6axis
Quote:7.  Is there a recommended calibration or validation procedure that should be performed before generating and running programs?
    You can use the Fairino controller emulator software for program validation.
I apologize for the inconvenience, but would it be possible for you to provide the procedure shown in the video in the form of a written step-by-step guide?
As it is difficult for us to fully understand the process from the video alone, we would greatly appreciate it if you could share any documentation, instructions, or a procedure manual explaining the workflow.
Thank you very much for your support and assistance.
Here are the instructions to load a program to your Fairino robot controller as a step by step guide (as requested).
Step 1: Import the Program Script
  1. From the top toolbar in the Program Teaching screen, click the Import icon.
  2. In the Import File dialog, click Browse....
  3. In the file browser dialog, navigate to the target folder and select the script file (e.g., tst3.lua in the video).
  4. Click Open, then click Import to upload the file to the console.
Step 2: Import the Point Table
  1. On the left-hand navigation sidebar, click on Manage Teaching.
  2. Under the Teaching Management view, select the Point table mode radio button at the top.
  3. Click the green Import button located next to the point addition controls.
  4. In the Import File popup, click Browse....
  5. Select the point table database file (e.g., point_table_tst3.db in the video) and click Open.
  6. Click Import in the dialog box to finish uploading.
Step 3: Apply the Point Table
  1. In the upper-right corner of the Teaching Management panel, locate the Select point table dropdown menu.
  2. Select the imported table (e.g., point_table_tst3.db).
  3. Click the blue Apply button. The point list table will populate with the imported coordinate points (p1 to p5) as shown in the video.
Step 4: Open the Program in Program Teaching
  1. Return to the Program Teaching screen by selecting it from the left sidebar.
  2. Click the Open File icon on the top program toolbar.
  3. In the Open File dialog, select the program file (e.g., tst3.lua) from the list.
  4. Click Open to load the program blocks into the editor.
Step 5: Clean Up Unused Program Lines (Optional)
  1. Review the loaded program blocks.
  2. Select any unnecessary comment or instruction line (e.g., -- Using nominal kinematics.).
  3. Click the Delete (trash can) icon in the editing toolbar to remove the block.
Step 6: Configure Mode and Execute Program
  1. In the top-right header, toggle the operational mode switch from Manual Mode to Auto Mode by clicking "Click to switch modes".
  2. Click the Play/Run button on the top execution bar.
  3. When the Confirmation of teaching program operation prompt appears ("Confirm to run the current teaching program!"), click Run.
  4. The 3D robot model will update and execute the trajectory points sequentially according to the loaded script and point table.
Let us know if you have any difficulties in understanding the steps!
