03-12-2026, 01:00 AM
How to keep robot's linear speed constant throughout a program? |
03-13-2026, 12:16 PM
You should add a set speed instruction to specify the speed you would like to maintain.
You can create other programs that move to the approach and retract position before running the path program. I recommend you to take a look at this getting started guide which cover the basics of running programs and subprograms, and also moving to approach targets: https://robodk.com/doc/en/Getting-Started.html
03-13-2026, 09:13 PM
Is it possible to set speed instructions when the TCP is moving from one target to another? In this scenario the distance between the two targets is large so I see the robot accelerating sharply during transition.
03-14-2026, 08:58 PM
Lookup acceleration/deceleration from the manual of the robot. Different vendors, different tags.
| 1 Guest(s) |
Powered by MyBB
