04-01-2022, 01:21 PM
I have a sample program in *.CSR format, how can I import to RoboDK?
Import CSR files |
04-03-2022, 05:18 PM
Are you referring to Panasonic CSR ASCII files? If so, it is currently not possible to import CSR files in RoboDK. On the other hand, you should be able to export Panasonic CSR program files for your robot. These are ASCII files that should be compiled so you can run them on your Panasonic controller.
For your information, it is not very complicated to write a script to read and load existing CSR files in RoboDK. This example shows the concept using a KUKA SRC program: https://robodk.com/doc/en/PythonAPI/exam...a-src-file |
| 3 Guest(s) |
