Import points and let e.g. a cube/AGV/step file follow that path?
Hi RoboDK.
So I was looking in your article regarding importing of points.
But, I wanted to make a "AGV" path, and then let e.g. a cube/AGV/stepfile follows that path doing simulation.
Would that be possible or is the import points only for simulating a robots TCP path?
So I saw this article: https://robodk.com/forum/Thread-Simulation-of-AGV and that seemed pretty nice with your stacked "mechanisms". But how should I then make a simple program, where the Cube/AGV goes like this:
1) Start in origin
2) Translate in X only
3) Rotate on the spot for e.g. 20 degree
4) Translate in X with the 20 degree offset
.rdk   AGVtest.rdk (Size: 2.43 KB / Downloads: 737)
it's not possible right now.
We have a feature for AVG coming out in the near future (one mechanism with XYZ and rotZ). I will see if we can use it with Curve Follow Project.
