Import robot programs from controller to RoboDK
Hi guys,
I wonder is there any possibility to import program witch was done online directly to RoboDK? I can't found any option in the interface.
Best regards
Piotr
Hi Piotr,
RoboDK supports some robot programs in simple formats, such as MOD/PRG files for ABB, JBI for Motoman, LS for Fanuc, SRC for KUKA, script for UR, etc. You'll be able to extract the robot movements.
Ok, but how can I do that? In the machining project? I try to import program done in RoboDK,  I saved it, and then export to RoboDK to check if it will work but it doesn't. Can you send me a simple program for KUKA witch can be imported to RoboDK? In attachment my code witch I want to import.
Piotr
.src   Path1.src (Size: 5.92 KB / Downloads: 748)
Oh, I checked it more precisely and now I see that I can import robot programs to RoboDK simply using File -> Open. I had thought that it isn't soo easy. Thanks for help.
Piotr
