Import src code
I would like for a comau robot to "generate program" using the robotdk post-processor, manually modify the pdl code and, then, execute/import the modify code in robotdk environment. Is is possible? Thanks.
This is currently not possible.
If you have someone in your team that can program, you could implement the import algorithm on your end. As an example, the following script shows how to import KUKA SRC files:
https://robodk.com/doc/en/PythonAPI/exam...a-src-file
