Import tool orientation around z-axis form CAM-Software
it was possible for me to feed roboDK with the machining Data of my CAM software.
I imported the curve with x, y, z, i, j, k and it works.
But I want to add a tool Orientation for every single point of the imported curve.
For our tasks it would be usefull to feed roboDK with a list of x, y, z, i, j, k, rotation_around_z.
Is there a way to do this or a workaround?
Thanks in advance.
Best Regards
Alex
.rdk   210830.rdk (Size: 630.59 KB / Downloads: 888)
Yes and No,
You can't import rot around Z from an NC file.
You can control the rotation around Z using the Robot Machining Project.
What find of orientation are you looking for?
Thank you Jeremy for your fast reply.
I looked up the options in Robot Machining Project.
If I understand it correctly, it's only possible to enter a constant rot(z) or to choose special options like follow path.
Follow path rot(z) can be ok sometimes,
but in my case I am searching for a possibillity to have full control over rot(z) individually for every single curve element.
Still possible, but with more work.
Look for the Excel sheet and video 13-C
https://drive.google.com/drive/folders/1...CCTdy-p7GW
If it works for you I could have a Python macro to help you do it a bit faster.
Hi Jeremy,
I tried it out. This works. Thank you.
I Just have to change the degree value of the third rotation (Yellow colored box).
A Python Macro would be nice:
Deleting the double commands and automaticly fill in the Degree-Value provided from txt-list or CSV-List.
Even if I am not customer, because my company has to decide which robot software to pick, maybe it helps other users as well.
Best Regards
Alex
Take a look at this macro.
It's a step in the right direction.
.py   Modify_Target_Orientation.py (Size: 1.17 KB / Downloads: 826)
(09-07-2021, 07:04 PM)Jeremy Wrote: Take a look at this macro.
Hey Jeremy,
Thank you for your effort.
Your macro prints out the following (and more):
Quote:Comau NS 12-1.85
T MoveJ 1
[[ -0.230, 0.958, -0.171 ],
 [ 0.769, 0.286, 0.572 ],
 [ 0.597, 0.000, -0.803 ]]
Pose(0.000, 0.000, 0.000,  0.000, 0.000, 0.000):
[[ 1, 0, 0, 0 ],
 [ 0, 1, 0, 0 ],
 [ 0, 0, 1, 0 ],
 [ 0, 0, 0, 1 ]]
Pose(-582.173, 4.540, 930.260,  -144.542, -9.822, -103.470):
[[ -0.230, 0.958, -0.171, -582.173 ],
 [ 0.769, 0.286, 0.572, 4.540 ],
 [ 0.597, 0.000, -0.803, 930.260 ],
 [ 0, 0, 0, 1 ]]
If I understand it correct, I have to fill my data in the new_pose array right?
I also found an existing script in RoboDK with the name "ImportCSV_XYZWPR.py". I changed it a little bit and it seems to work.
Blessings.
Alex
The script you mentioned is part of our examples in the documentation, available here:
https://robodk.com/doc/en/PythonAPI/exam...ram-xyzwpr
It requires importing the full pose given Euler angles or UVW rotation vector (not ijk vector, which is the tool Z axis and not a full pose constrain).
On the other hand, if you have ijk vector (tool Z axis) you can use the function point_Zaxis_2_pose:
https://robodk.com/doc/en/PythonAPI/robo...xis_2_pose
This will give you a pose, then, you can rotate around Z given your additional parameter.
Thank you for your fast support.
