Importing DED from Fusion
I can import regular toolpaths directly from fusion, also the regular 3d print slicer stuff seems to import ok.
However; Fusion has this Direct Energy Deposition which let me use multi axis deposition toolpaths. This import does not work. It throws a milling toolpath error.
I can of course import directly from gcode or apt file. FYI
The RoboDK Add-in for Autodesk Fusion 360 uses the APT ISO 4343 post processor by default. You can find this post processor here:
C:/RoboDK/Other/Plugin-Fusion360/RoboDK/v39/apt_RoboDK.cps
Do you have the same issue when you export your toolpath using this APT post processor?
I assume you were able to export it using G-code. In this case, you could replace the apt_RoboDK.cps Post Processor that the RoboDK add-in for Fusion uses by default.
If it still fails, can you provide us with the F3D file and steps to reproduce this issue?
well, I seem to not have tried every option here.
So the post (apt) works just fine, both fusions and robodk.
However standing in the additive tab/space in fusion and trying to import fails and throws the error.
Going to the Tools tab works fine! So there we have it.
Interesting... thank you for your feedback.
We'll try to reproduce this and make sure it does not raise an exception.
