Dear Ms. and Mr. in RoboDK,
I am writing to look for some help from you about importing the geometry file.
I am planning to use gantry "H-bot" and "Utilities-->Curve follow project" for simulation in a 3D printing project. But right now I am still confused how to import different types of files as the "static environment object" or "to be printed object".
More specifically, my questions are listed below:
1. Till now I have tried to "drag and place" an .dae object in RoboDK and select the "curve follow project" to detect the edges of the object as "curves", and then let the TCP of the robot to follow and work. I want to ask if there can be some improvements using this method?
2. I noticed that in a tutorial (https://www.youtube.com/watch?v=FwYJ7FEfdLE) Jimmy imported serial of points to realize the curve follow project.(see the attachment) I would like to understand: how was this done? What kind of file did he import? How to realize this effect----points on a planar surface as paths for the robot to follow? What is the detailed process to realize this?
3.I am also interested, in terms of importing geometry files, what kinds of file types are accepted for my task? And how are their handling method respectively?
Thank you very much and looking for your reply.
Carrie
Carrie
