10-07-2019, 03:55 PM
Dear all.
Is it possible to import scanned coordinates instead of using a CAD drawing?
We are doing non destructive testing by moving our mesurement head (mounted on a UR10 robot) at a specifi distance, perpendicular to the surface of a part. The normal way, would be to import a CAD drawing, plan the path and then do the testing. But, quite often the real part and the CAD drawing doesn't match the real part because of warping due to production or other problems. In other cases we simply lack the CAD drawing, so we need to make CAD drawing from the real part.
Lately we thought, that it would be much easier, to mount a laser distance sensor on the robobt and scan the part by moving the robot in a simple rectangular shape over the part. Then use the found distnace together with the coordinates and put the part in RoboDK.
By this we would get the parts real shape and also its exact position, without the need of an exact alignement.
Was this done before? If yes, please point me to the according thread or example. If no, can you give me a hint of how this could be possible?
Many thanks
Bernhard
Many thanks
Bernhard
