Threads: 6
2
The step models for a lot of my parts have coloring already included in them, but when I import into roboDK I always get a white part. Is there a way to keep coloring when importing? I'm coming from fusion360 with most of my parts if that makes a difference and I've verified that the exported STEP files do indeed have color included.
Threads: 6
2
I can confirm i'm exporting step 214 files and that they have color (it shows up in other tools). but the color does not appear in roboDK
75
Hi Chris,
This is usually because you have to color on top of one another.
"Double click the object" -> "More Option" -> "Change colors" -> Try deleting the "grey" that covers everything.
It usually works.
227
Thank you for your feedback.
You should also be able to right click an object, select Split Object and delete duplicate geometry. This usually happens if you add material properties to your 3D models. You can later select all sub components and select "Merge".
