When I import a robot and a robot program I need either collect the values relating to position/join values at each instruction in the robot program or move the robot to each instruction individually and collect the required information. I cant see a way to step through the program or just execute a specific instruction through the API. I am using the C# API. Any help would be appreciated 😀
Joint and Position values for each instruction |
01-08-2024, 02:42 PM
(01-08-2024, 11:53 AM)AdamNeale Wrote: When I import a robot and a robot program I need either collect the values relating to position/join values at each instruction in the robot program or move the robot to each instruction individually and collect the required information. I cant see a way to step through the program or just execute a specific instruction through the API. I am using the C# API. Any help would be appreciated 😀 Everyone relax I found the values I needed in GetInstruction() 🎉😎
01-09-2024, 11:57 AM
Great! Thank you for letting us know.
This example can also help you retrieve information related to program instructions by using the API: https://robodk.com/doc/en/PythonAPI/exam...structions |
| 1 Guest(s) |
Powered by MyBB
