Hi All,
Seeking support with getting the right settings for RoboDK curve following as per the examples of the propeller polishing and the canoe polishing.
I have a wooden seat that is "bum" shaped, so not flat. The seat is made on a CNC machine so we have the CAD file available.
I have a sander on the end of a UR10e robot that I want to do the sanding of the seat with.
I've created a sanding toolpath in Solidworks, the process is similar to the canoe example that uses Inventor (https://www.youtube.com/watch?v=NoefxDYIwFA)
Exported that to RoboDK and using the curve follow feature, I can have the robot follow the path, but the sanding head stays parallel to the table, rather than keeping the tool face flat to the surface of the seat.
I've attached images which will hopefully help.
I'm nearly there with this, it's taking me ages to get here as I've had to do it in bits here and there! I just want to get this running now and finish it off.
I'm not sure though, whether I need to do more in Solidworks before exporting the toolpath, or if it's wrong settings in RoboDK.
Any ideas or pointers would be greatly appreciated!
M
M
