Kinematic calculation deviation between RoboDK and UR robot controller
Dear everyone,
I found that under the same joint values and TCP settings, there is a deviation in the TCP data calculation results of RoboDK and URrobot controllers. Additionally, I have updated the robot parameters in RoboDK based on the DH model data found in the robot controller support files, which are shown in the attachment. Finally, I have a UR10e and a UR5, they both have this problem.
Looking forward to suggestions from relevant experts.
Best Regards!
Guoquan Zhang
.rdk   Kinesiology.rdk (Size: 3.24 MB / Downloads: 625)
.txt   urcontrol.conf.txt (Size: 1.95 KB / Downloads: 552)
Each UR controller has unique robot kinematic parameters because each robot is calibrated.
You should follow these steps to load the controller kinematics into RoboDK:
https://robodk.com/doc/en/Robots-Univers...Kinematics
(02-29-2024, 09:04 AM)Albert Wrote: Each UR controller has unique robot kinematic parameters because each robot is calibrated.
Dear Albert
Thanks for your reply!
I finally solved the problem with this method. Firstly, I try to modify the DH model by directly changing data in the 'parameters' of the robot object, like the method in the picture below. I guess this may be because the two use different DH model methods. Besides, I find this method from the Chinese documentation. I hope this can help you improve the documentation.
Best regards
Guoquan Zhang
Perfect, thank you for letting us know!
