10-20-2020, 01:59 PM
Hello there,
i'm trying to get a Kuka IIWA running via online programming.
In RoboDK RobotDrivers it says that the Kuka IIWA is supported
From the update list of RoboDK i can see:
"New in RoboDK v4.0.0 (2019-10-09)
As far as i found out there is really a "apikukaiiwa.py" available to select for connecting to the iiwa in the roboDK user interface.
I tried to connect over the robodk robot connect interface with this driver chosen, but it said in the log "[WinError 10061] No connection could be made because the target machine actively refused it".
I believe that i have to start a program downloaded over java sunrise workbench to my kuka iiwa that opens this port on the robot and then listens to commands.
Sadly i did not find any tutorials or java files for this purpose anywhere.
How do i set up my robot to listen on the given port?
Would be happy if someone could point me to a solution or tutorial on how to use the provided apikukaiiwa.py driver asap, because i need to control the robot directly from robodk simulation for an upcoming project demo.
- Added driver for KUKA IIWA (apikukaiiwa.py)"
