Lock TCP documentation
Hello guys,
I am doing some modifications on XBox Controller script and was wondering if there is more functions in LockTCP Plugin? Would like to ask the status of a current tool. Is it possible to do it or does it have only "LOCK" and "UNLOCK"?
Something like:
RDK.PluginCommand("Lock TCP", "STATUS", tool.Name()) == "Locked" or
RDK.PluginCommand("Lock TCP", "STATUS", tool.Name()) == "Unlocked"
The thing is, on Xbox Controller, I am switching between robots with "BTN_SELECT" and would like to get the status of the active tool on the newly selected robot :)
Thank you very much!
Kind regards,
Tom
Hi Tom, nice to see you are putting the Game Controller App to good use!
The Lock TCP plug-in currently does not support the ability to retrieve the status of a robot. However, it should be very easy to add! You can find the source code here:
https://github.com/RoboDK/Plug-In-Interf...CP.cpp#L80
We should add this feature at some point, but feel free to open a pull request until then.
Hi Sam!
That was exactly I was looking for!
Yes, I am trying to implement some additional functions of Xbox Controller and find a workaround for not heaving the Teachpendant while doing some simulations :)
Here is the code I did until now so maybe you can take a look and see if you can use it in the future? Still under constuction but it works for "Translation" motion. I am working on rotation with locked TCP now.
Kind regards,
Tom
.py   XboxController.py (Size: 17.5 KB / Downloads: 719)
For those interested, the Game Controller Add-in and its source code are available here:
https://robodk.com/addin/com.robodk.app.gamecontroller
https://github.com/RoboDK/Plug-In-Interf...troller.py
