Low cost education robot
i have previously posted about my project to try and integrate the Mover6 robot into ROBODK. unfortunately i have not received anything back that can be of use from the manufacturer of the arm so i am trying to look at this from a different angle.
Are you able to advise me on a entry level low cost robot that is integrated with robodk already? that i may be able to purchase?
Also, i have thought about removing the chip from the Mover6 robot and connecting the motors on the robot arm to a arduino board with drivers. are you able to advise me if this could be an easier route than trying to get the configuration of the mover6 to work with robodk? i seem to be having issues with the PCAN-usb configuration.
You can find the Mover6 in our online robot library:
https://robodk.com/robot/CPR/Mover6
You can also browse alternative by using a small payload range:
https://robodk.com/library#filter?type=6...load=0.2-2
3 Guest(s)
