Machining parameters get and set Path to tool offset
I'm looking to get and set the parameter inside a Machining Project called "Path to tool offset" with the API (Python).
This parameter is not accessible with :
machiningsetting = m.setParam("Machining")
Any ideas ?
Thank you !
To set the path to tool offset of a robot machining project with the API you can simply use Pose and setPose.
For example, to set a path to tool rotation of 90 deg around the Z axis you can do:
m.setPose(rotz(90*pi/180))
Oh so easy, thank you ahah
I wish you very good holidays!
Thank you for your feedback and Happy Holidays!
