09-29-2023, 08:41 PM
Does the Mastercam plug-in work with Mastercam2024 yet? I'm not seeing the commands in the ribbon configuration.
Mastercam 2024 |
10-01-2023, 05:53 PM
Can you follow the manual installation steps of the RoboDK plugin for Mastercam described here?
https://robodk.com/doc/en/Plugin-Masterc...ualInstall You may need to update or add the Mastercam install path: C:\Program Files\Mastercam 2024\Mastercam\chooks You can find the plugin installer BAT file here: C:\RoboDK\Other\Plugin-Mastercam\Plugin_Install...bat |
| 1 Guest(s) |
