Modify external axes behavior using setParam
I'm trying to create a script to switch the external rotary axis (see photo), but when I run my script, nothing changes. I think there's an issue with the setParam function. Could you help me?
import tkinter as tk
from tkinter import messagebox
from robodk import robolink    # RoboDK API
# Connexion à RoboDK
RDK = robolink.Robolink()
# Fonction pour activer un axe externe spécifique
def activer_axe_externe(nom_axe):
    # Récupérer tous les robots (y compris ceux ayant des axes externes)
    robots = [item for item in RDK.ItemList() if item.Type() == robolink.ITEM_TYPE_ROBOT]
    for robot in robots:
        # Vérifier si le robot a des axes externes
        ext_joints = robot.getParam('ExtJoints')
        if ext_joints:
            # Désactiver tous les axes en mettant une liste vide
            robot.setParam('ExtJoints', '')
            robot.setParam("Synchro", "0")  # Désynchroniser d'abord
    # Activer l'axe externe sélectionné
    axe_externe = RDK.Item(nom_axe, robolink.ITEM_TYPE_ROBOT)
    if axe_externe.Valid():
        axe_externe.setParam('ExtJoints', '7')  # Activer l'axe externe (valeur 1)
        robot.setParam("Synchro", "1")
        messagebox.showinfo("Succès", f"Axe externe activé: {nom_axe}")
    else:
        messagebox.showerror("Erreur", f"Axe externe non trouvé: {nom_axe}")
You can find an example on how to change configurations for external axes here:
https://robodk.com/doc/en/PythonAPI/exam...n-settings
What exactly are you trying to do?
RoboDK can only handle a single independent rotary axis. I created a script with a pop-up to associate the desired external axis.
Here is the code:
    robots = [item for item in RDK.ItemList() if item.Type() == robolink.ITEM_TYPE_ROBOT ]
        if ext_joints:
    axe_externe = RDK.Item(nom_axe, robolink.ITEM_TYPE_ROBOT )
        axe_externe.setParam('ExtJoints', '8')  # Activer l'axe externe (valeur 1)
    else:
# Fonction appelée lorsque le bouton "Valider" est cliqué
def valider():
    selection = var.get()
    if selection:
        activer_axe_externe(selection)
    else:
        messagebox.showwarning("Avertissement", "Veuillez sélectionner un axe.")
# Création de la fenêtre principale
root = tk.Tk()
root.title("ACTEMIUM - Sélection de l'Axe Externe")
root.geometry("400x250")  # Définir la taille de la fenêtre
root.configure(bg="white")  # Définir le fond de la fenêtre en blanc
# Ajout d'un texte explicatif
explication = ("Choisissez un axe externe à activer. "
              "Tous les autres axes seront désactivés.")
tk.Label(root, text=explication, wraplength=350, bg="white", justify="center", font=("Helvetica", 12)).pack(pady=20)
# Liste des axes externes
axes_externes = ['TIG', 'MAG']
# Variable pour stocker la sélection de l'utilisateur
var = tk.StringVar(value=axes_externes[0])
# Création des boutons radio pour chaque axe
for axe in axes_externes:
  tk.Radiobutton(root, text=axe, variable=var, value=axe, bg="white", font=("Helvetica", 10, "bold")).pack(anchor=tk.CENTER, pady=5)
# Boutons de validation et d'annulation avec marges ajustées et taille augmentée
tk.Button(root, text="Annuler", command=root.destroy, font=("Helvetica", 12), width=10, height=2).pack(side=tk.LEFT, padx=40, pady=20)
tk.Button(root, text="Valider", command=valider, font=("Helvetica", 12), width=10, height=2).pack(side=tk.RIGHT, padx=40, pady=20)
# Lancement de la boucle principale de l'interface
root.mainloop()
You can find an example synchronizing a robot with a 3 axis turntable for welding here:
https://robodk.com/example/Synchronizati...0ID-8-2-00
I also attached a sample project that is similar to what you describe that we'll soon add to the library.
Where did you get the parameters ExtJoints and Synchro from? I don't think they are documented and should have no effect.
.rdk   Welding-with-3ax.rdk (Size: 6.82 MB / Downloads: 438)
(03-31-2025, 07:16 AM)Albert Wrote: You can find an example on how to change configurations for external axes here:
I am looking to change the mechanism, not to modify these parameters.
(03-31-2025, 09:10 AM)Albert Wrote: You can find an example synchronizing a robot with a 3 axis turntable for welding here:
Thank you for your feedback, but there is no script that handles the mechanism change. The 'ExtJoints' parameter is likely incorrect (I had asked an AI). In the API documentation, I can't find the function that could perform the change shown in the photo attached to the post.
The mechanism change can be done using the API and the setLink function.
Example:
robot = RDK.Item('robot name')
axis_1 = RDK.Item('Axis_1')
axis_2 = RDK.Item('Axis_2')
axis_3 = RDK.Item('Axis_3')
# Set axis one at the desired location (0 deg for example)
axis_1_joints = [0]
axis_1.MoveJ(axis_1_joints)
# Synchronize the axes
robot.setLink(axis_3)
Here's the corrected code, in case it's helpful to anyone, and thanks again for the support.
from tkinter import ttk
# Connection to RoboDK
# Get the list of robots with 3 or more axes
robots_3axes = []
    if len(robot.Joints().list()) > 3:  # Filter
        robots_3axes.append(robot)
robot_names = [robot.Name() for robot in robots_3axes]
# Create the main window
root = tk.Tk()
root.title("ACTEMIUM - External Axis Selection")
root.geometry("400x300")
# Variable to store the selected robot
selected_robot = tk.StringVar(value=robot_names[0] if robot_names else "")
# List of external axes
external_axes = ['Plateau', 'TIG', 'MAG']
external_axes_display = ['TIG', 'MAG']
external_axes_pos_plateau = [0, 180]
axis_var = tk.StringVar(value=external_axes_display[0] if external_axes_display else "")
# Function to activate a specific external axis
def activate_external_axis(axis_name, robot_name):
    if robot_name:
        try:
            robot = RDK.Item(robot_name, robolink.ITEM_TYPE_ROBOT)
            if robot.Valid():
                full_axis_name = ""
                for full_name in external_axes:
                    if axis_name in full_name:
                        full_axis_name = full_name
                        break
                if full_axis_name:
                    axis_item = RDK.Item(full_axis_name)
                    if axis_item.Valid():
                        robot.setLink(RDK.Item('Plateau'))
                        if axis_name == 'TIG':
                            robot.MoveJ([0, 0, 0, 0, 0, 0, external_axes_pos_plateau[0]])
                        elif axis_name == 'MAG':
                            robot.MoveJ([0, 0, 0, 0, 0, 0, external_axes_pos_plateau[1]])
                        robot.setLink(axis_item)
                        messagebox.showinfo("Success", f"External axis activated: {axis_name} on {robot_name}")
                        robot.MoveJ([0, 0, 0, 0, 0, 0, 0])
                    else:
                        messagebox.showerror("Error", f"External axis not found: {full_axis_name}")
                else:
                    messagebox.showerror("Error", f"External axis not found: {axis_name}")
            else:
                messagebox.showerror("Error", f"Robot not found: {robot_name}")
        except Exception as e:
            messagebox.showerror("Error", f"An error occurred: {e}")
    else:
        messagebox.showwarning("Warning", "Please select a robot.")
# Function called when the "Validate" button is clicked
def validate():
    selected_axis = axis_var.get()
    selected_robot_name = selected_robot.get()
    if selected_axis and selected_robot_name:
        activate_external_axis(selected_axis, selected_robot_name)
    else:
        messagebox.showwarning("Warning", "Please select an axis and a robot.")
# Dropdown list for robot selection
ttk.Label(root, text="Select Robot:", background="white").pack(pady=(20, 5))
robot_combobox = ttk.Combobox(root, textvariable=selected_robot, values=robot_names)
robot_combobox.pack(pady=5)
# Set the default selection only if robot_names is not empty
if robot_names:
    robot_combobox.current(0)
# Explanation text
explanation = ("Choose an external axis to activate. "
              "All other axes will be deactivated.")
tk.Label(root, text=explanation, wraplength=350, bg="white", justify="center", font=("Helvetica", 12)).pack(pady=10)
# Radio buttons for each axis
if external_axes_display:
    for axis in external_axes_display:
        tk.Radiobutton(root, text=axis, variable=axis_var, value=axis, bg="white", font=("Helvetica", 10, "bold")).pack(anchor=tk.CENTER, pady=5)
else:
    tk.Label(root, text="No external axes available.", bg="white").pack(pady=10)
# Validate and Cancel buttons
tk.Button(root, text="Cancel", command=root.destroy, font=("Helvetica", 12), width=10, height=2).pack(side=tk.LEFT, padx=40, pady=20)
tk.Button(root, text="Validate", command=validate, font=("Helvetica", 12), width=10, height=2).pack(side=tk.RIGHT, padx=40, pady=20)
# Start the main loop
root.mainloop()
Great! Thank you for your feedback.
