Threads: 1
I want to know if i can use MoveL_Test, to test the collisions with an object attached to a tool and other objects.
Im doing a python program to palletize objects, and I want to know if in the movement is there a collision before the robots put the object in the pallet.
Thanks in advance!
Threads: 1
But if I am creating the objects dynamically, that is, the objects are not in the layout from the beginning and how can I adjust the parameters?
Threads: 1
Thanks,
Do you have any example to test this function? I want to test the collision between an object and another 3 objects?
Threads: 1
I have another doubt,
How can I test the function just if the robot is doing a moveL_test example:
nuevo_target = RDK.AddTarget(f"Pose Calculada {objeto_count}")
nuevo_target.setVisible(False, False)
nuevo_target.setPose(PosePallet1)
nuevo_target.setAsJointTarget()
robot_joints = robot.Joints()
can_move_linear = True
issues = robot.MoveL_Test(robot_joints, PosePallet1)
can_move_linear = (issues == 0)
if issues==0:
# Verifica la colisión con todos los objetos en la estación
time.sleep(0.1)
robot.setPoseFrame(Robot_Frame)
robot.MoveJ(Aprox_palletA)
robot.setPoseFrame(frame_palletA)
robot.MoveL(PosePallet1)
TCP_Off(tool, frame_palletA)
with open(ruta_log, 'a') as log_file:
current_time = datetime.datetime.now().strftime("%Y-%m-%d %H:%M:%S")
log_file.write(f"no Error de movimiento en {archivo_txt} con objeto {objeto_count} en {current_time}\n")
else:
#quitar de aqui a .2
joints_robot = robot.Joints()
log_file.write(f"Error de movimiento en {archivo_txt} con objeto {objeto_count} en {current_time}\n")
I want to know if in the movement of moving the robot to posepallet1 with the object attached to the tool it collides with any other object in the station, I cannot make collision map because the objects appear dynamically in the simulation
