Need Help Programming a Wrapping Machine in RoboDK
Hello everyone,
I am currently working on a simulation in RoboDK and I need to integrate a wrapping machine into the process. I found a suitable wrapping machine model on GrabCAD, but I am unable to attach the CAD file here. However, I can provide the download link:
https://grabcad.com/library/automatic-st...-machine-1
My main issue is that I don’t know how to properly program this machine inside RoboDK. I tried several approaches, but I couldn’t get anything to work.
If anyone has experience with programming such machines or can guide me on how to set up its motion/logic in RoboDK, I would greatly appreciate your help.
Also, if someone already has a working script or an existing wrapping machine setup that I could use as an example, that would be extremely helpful.
Thank you in advance!
This link of the documentation shows how you can model robots and custom mechanisms:
https://robodk.com/doc/en/General.html#ModelRobot
Can you share more information about what you tried? Do you have the RoboDK project file with each joint split as a sepate object?
Hello again,
I’m coming back with some additional information regarding my issue. I found another CAD file for the wrapping machine, and while the rotation of the table works fine, I am still dealing with a major problem.
When I try to use JOINT1 (translation), the translation also affects the rotary table, even though I specifically selected only the object that holds the wrapping film (this is the part I want to translate along the Z-axis). The rotary table should remain unaffected, but it moves as well.
Do you have any idea what might be causing this behavior or how I can properly separate these motions?
If needed, I can also provide the CAD file or the RoboDK project so you can take a closer look.
Thank you!
If you can share your project in RoboDK and the attempts you are doing it will better help us understand this issue and better help you.
.rdk   incercare_wp.rdk (Size: 2.42 MB / Downloads: 340)
I have attached a file that contains what I have worked on and tested so far.
I would really appreciate any feedback or suggestions for improvement.
Thank you
I believe you should not provide a 3D model for your first joint (you can leave it empty or select None when you build your mechanism). It looks like joint 1 and joint 2 are the round plate.
Also, I'm not sure where the rotation should happen but you can align the Z axis with the rotation axis.
.rdk   Modeling-2-axis-mechanism.rdk (Size: 92.25 KB / Downloads: 300)
I think there was some confusion in my previous post, so I want to clarify the real issue.I am trying to simulate a stretch-wrapping machine, and what I need is for the turntable to remain completely fixed when the vertical translation (Z movement) occurs. When the carriage moves up or down along the Z axis, the turntable should NOT be translated or moved at all. It must stay in place, just like in a real stretch-wrapping machine. At the moment, RoboDK applies the Z translation to the turntable as well, which is exactly what I want to avoid. To make it clearer, I will also provide a video of a real stretch-wrapping machine so you can see exactly the motion I’m trying to simulate.
Thank you!
https://www.youtube.com/watch?v=pZByYLFNVuE
OK I didn't understand what you were trying to do in the first place.
In this case you should model the 2 moving parts as separate mechanisms: one axis to rotate and a separate axis to translate.
I tried setting up two mechanisms:first a rotation and then a translation but I still can’t get it to work correctly. Could you help me with this if you can?
Thanks!
Here is an example of how you can make a wrapping machine using 2 separate mechanism in RoboDK.
I made this example using your model and included basic programs, I hope this help.
.rdk   Wrapping_Machine.rdk (Size: 78.78 KB / Downloads: 372)
