02-15-2022, 01:52 PM
Thanks for your reply.
I've sent the project and a drawing to clear up the 90 degrees rotation.
Position unreachable - Linear Rail - Fanuc |
02-15-2022, 04:44 PM
You sent it to me? Because I didn't receive anything.
02-15-2022, 09:27 PM
That's strange, I used two email addresses I received from the RoboDK distributer in The Netherlands.
Anyway: Your reply made me double check a few things: The visibility of the robot-frame was turned off. The visibility of the wagon of the rail was turned on and I misinterpreted this frame as if it were the robot-frame. In fact, the (invisible) robot-frame was rotated 180 degrees around the Z-axis. After correction, and teaching the fixed targets again, the program runs now in RoboGuide. Next step is to re-master the Joint_1 axis of the real robot and test the new files generated by RoboDK. Emile
02-15-2022, 09:52 PM
Great improvement!
| 1 Guest(s) |
