Hi!
Problem connecting RoboDK and MasterCAM. When I select RoboDK - Update selected operations in the MasterCAM environment, the following warning appears: 'Nothing to simulate. Operation aborted '.
What could be wrong? I have the operation selected in Mastercam and Machining Reference in RoboDK.
223
Hi Bruno,
If you use MasterCAM I recommend you to use the native MasterCAM NCI files instead of an NC file. This is the default behaviour when you use the RoboDK Plugin for MasterCAM. NC files depend on your post processor and you are likely to see strange behaviour.
If you can post the NCI and/or NC files we can better help you.
Threads: 4
Yes Jeremy,
There are no Approach and Retract Moves defined in RobotDK. I clicked on "Remove" for both, just in case, but the Simulation still begins and ends at X0Y0Z0 as defined in the MasterCam model. In MasterCam itself there are no Approach or Retract Moves defined. The MasterCam simulation correctly executes without adding the extraneous moves at the beginning and end of the program.
75
Do you have the G-code (NCI) that was transferred from MasterCAM to RoboDK?
It should be in your Temp file
