Python CSV file to Program (XYZ) with 7. axis
I have tried running the Python Script "ImportCSV_XYZ" with updating the speed in the program for each point. Unfortunately, I cannot get the 7th axis to run with the program, as the 7th axis does not move.
I have tried selecting "Move External Axes" under Axes Optimization -> "More Options".
How do I make the 7th axis move in the program?
Best regards
Jonas
.rdk   CSV file to program (XYZ) with 7. axis robot.rdk (Size: 3.68 MB / Downloads: 480)
.py   ImportCSV_XYZ.py (Size: 4.81 KB / Downloads: 480)
.zip   CSV File.zip (Size: 516 bytes / Downloads: 411)
I have attached a few pictures where;
1) "Program Sample XYZS 7th axis not moving" is how the robot + 7th axis moves at the end point of the XYZS program
2) Move 7th axis with moving ToolFrame with respect to Reference Frame is how the robot + 7th axis must be able to move in the end point of the program. However, this is done by manually moving the robot + 7th axis in the Z-direction, where it works with the robot being synchronized with the 7th axis
Best regards
Jonas
2) Move 7. axis with moving ToolFrame with respect to Reference Frame.png    1) Program Sample XYZS 7. axis not moving.png
I would recommend using the Curve Follow Project to apply optimization settings individually for different trajectories
You can import this CSV file as a curve using the File->Open command
You can use the Program Events tab to set the required speeds or r.click on generated program->Show instructions and then add the required additional speed commands
I attached your station with an example CFP based on the CSV file provided.
We can discuss your project in more detail if you contact us at info@robodk.com.
.rdk   example_cfp.rdk (Size: 3.68 MB / Downloads: 513)
