Python: modify timed out
I am using
MoveJ_Test(j1, j2, minstep_deg=-1)
but when making the minstep more accurate, for example minstep_deg=0.01, I get the following error:
Quote:File "C:\Python34\lib\robolink.py", line 369, in _rec_int
    buffer = self.COM.recv(4)
socket.timeout: timed out
Is there any way to increase the time out? Or any trick to keep the process attached while RoboDK is still calculating?
Are you using the latest version?
Default timeout for calculation is set to 1 hour (3600 seconds). Do you need more time?
If so, you can also manually change it in the implementation of the MoveJ_Test file if you need more time.
3 Guest(s)
