Question with painting spray on.py
I have a question about RoboDK when painting: how can I use two robots to paint the same object like "inspection object"?
When I run "progmain" the result is right, but when I run "prog12 ", I can't find the painted color on obj? I have tried to change obj and tool variables in the PY file.
.rdk   multi painting520.rdk (Size: 2.65 MB / Downloads: 259)
You can specify the tool inside the script before triggering the paint operation. For example:
tool = RDK.Item("Paint gun2", ITEM_TYPE_TOOL)
I attached a working example for the program you are trying to run with the ABB robot.
.rdk   multi painting520-v2.rdk (Size: 2.66 MB / Downloads: 194)
