04-16-2024, 04:57 AM
(This post was last modified: 04-16-2024, 04:59 AM by JaeHong Yoo.)
Hello, thank you for always helping me.
I would like to know how I can use RoboDK to give movement commands to KUKA robots in real time.
As far as I know, there is a way to execute the 'Move' command in RoboDK in the same way as clicking the 'Move Joints' button through the C3 bridge communication that I planted in RoboDK's kukabridge driver and KUKA robot controller.
But I want to keep the RoboDK's robot model moving in real time. For example, if RoboDK's robot model moves, the actual KUKA robot moves in the same way.
Then you get the same results as controlling a real KUKA robot in RoboDK.
I would really appreciate it if you could tell me how to achieve my goals.
The code below is an example that I have written to allow RoboDK and KUKA robots to move through command delivery in real time while communicating with each other:
import robodk.robomath
from robodk.robolink import *
from robodk.robomath import *
import time
linear_speed = 10
angular_speed = 180
joints_speed = 5
joints_accel = 40
is_stop = False
class rdk2kukaControl:
def __init__(self):
self.RDK = Robolink()
self.robot = self.RDK.Item('KUKA KR 70 R2100')
self.tool = self.robot.Tool()
self.reference = self.RDK.Item('Baseline')
self.tcp_obj = self.RDK.Item('tcp_obj')
self.bbox = self.RDK.Item('bbox')
self.current_joints = self.robot.SimulatorJoints()
# bool
self.is_collide = False
self.within_bbox = True
# Boundary limits
self.min_x, self.max_x, self.min_y, self.max_y, self.min_z, self.max_z = [-90, 90, -90, 90, 10, 190]
# Initial robot settings
self.robot.setPoseFrame(self.reference)
self.robot.setPoseTool(self.tool)
self.robot.setSpeedJoints(joints_speed)
def check_bbox(self):
relative_pose = self.tcp_obj.PoseWrt(self.reference)
kukaPose = Pose_2_KUKA(relative_pose)
tcp_x, tcp_y, tcp_z = kukaPose[:3]
if any([
tcp_x < self.min_x, tcp_x > self.max_x,
tcp_y < self.min_y, tcp_y > self.max_y,
tcp_z < self.min_z, tcp_z > self.max_z
print("TCP out of range!!")
self.within_bbox = False
return True
else:
print("TCP within range.")
return False
def collision_detection(self):
if self.RDK.Collisions() > 0:
print("Collided!!")
self.is_collide = True
else:
print("is not Collided.")
def order2kuka(self):
start_time = time.time()
if self.current_joints != joints:
print("Change joint values are: ", joints)
self.robot.MoveJ(joints)
print("Robot MoveJ")
self.current_joints = joints
# Execution time
print(f"Execution time: {time.time() - start_time} seconds")
time.sleep(0.004)
def run(self):
while True:
if not self.is_collide and self.within_bbox:
print("order2kuka")
self.order2kuka()
else:
print("can't order2kuka!!")
break
print("rdk2kukaControl Program has ended.")
if __name__ == "__main__":
kuka_controller = rdk2kukaControl()
kuka_controller.run()
