Reference frame of points making the slicing path
Dear Community,
When we slice 3D model in robodk with slic3r, is it possible to choose the reference frame direction of the points making the path ?
For exemple, in attached file, is it possible to change the direction of the arrows ?
Thank you for your reply.
If you simply want to flip the arrow, the simplest solution would be the lot the arrow as-is and rotate your TCP 180 degrees around either its X or its Y.
You will also have to rotate the reference frame.
Thanks Jeremy
