Request to add Productive Robotics OB7 robot
Would it be possible for RoboDK to add the standard OB7 robot to the library? Currently only the OB7 Max 8 is there.
Attached are the files that I received from Productive Robots. They referred me to RoboDK technical support for this.
.zip   model.zip (Size: 3.72 MB / Downloads: 349)
Can you provide the model in .step format?
Yes. Here I've attached the files
.zip   model_STEP.zip (Size: 6.44 KB / Downloads: 418)
The step files seems to be empty, can you provide another file?
(12-17-2025, 02:48 PM)Olivier Wrote: The step files seems to be empty, can you provide another file?
New files are here, thank you
.zip   OB7 Without Stand.zip (Size: 4.19 MB / Downloads: 348)
Can you send the original homed model? This one seems to be exported from a station.
Attached is what the manufacturer sent me. If this is not the file you need, can you please provide more details or examples about it? Do you mean homed model as it will show in simulation or be positioned on the based?
.zip   OB7 with Stand.zip (Size: 6.64 MB / Downloads: 333)
Can you provide the robot with all the joints positioned at zero? By homed, I mean the robot having its joints in default position.
Productive Robotics sent me this file. Hopefully this works.
.zip   PUB OB7 Homed.zip (Size: 2.47 MB / Downloads: 279)
This file work, here is the robot.
It will be added to the library soon, let me know if something is incorrect with it.
.robot   Productive-Robotics-OB7.robot (Size: 1.84 MB / Downloads: 354)
