Threads: 1
0
12-12-2025, 06:52 PM
(This post was last modified: 12-15-2025, 09:21 AM by Albert .)
Would it be possible for RoboDK to add the standard OB7 robot to the library? Currently only the OB7 Max 8 is there.
Attached are the files that I received from Productive Robots. They referred me to RoboDK technical support for this.
model.zip (Size: 3.72 MB / Downloads: 257)
Threads: 0
21
Can you provide the model in .step format?
Threads: 1
0
Yes. Here I've attached the files
model_STEP.zip (Size: 6.44 KB / Downloads: 297)
Threads: 0
21
The step files seems to be empty, can you provide another file?
Threads: 0
21
Can you send the original homed model? This one seems to be exported from a station.
Threads: 1
0
Attached is what the manufacturer sent me. If this is not the file you need, can you please provide more details or examples about it? Do you mean homed model as it will show in simulation or be positioned on the based?
OB7 with Stand.zip (Size: 6.64 MB / Downloads: 243)
Threads: 0
21
Can you provide the robot with all the joints positioned at zero? By homed, I mean the robot having its joints in default position.
Threads: 1
0
Productive Robotics sent me this file. Hopefully this works.
PUB OB7 Homed.zip (Size: 2.47 MB / Downloads: 206)
Threads: 0
21
This file work, here is the robot.
It will be added to the library soon, let me know if something is incorrect with it.
Productive-Robotics-OB7.robot (Size: 1.84 MB / Downloads: 233)
