RoboDK crashing
When using robodk, I am running into a shutdown whenever a station is opened and just generally making changes. error just states. Program has stopped working. I have attached the debug file after a crash happened.
Any help much appreciated
You forgot to attach the debug file. Could you attach it?
More information on how to generate this file here:
https://robodk.com/forum/Thread-Problems...90#pid1090
Was RoboDK working in the past and suddenly stopped working?
Attachment should be added now.
It was working but haven't used it in 5 months and is crashing now
.txt   RoboDK.debug.txt (Size: 4.5 KB / Downloads: 444)
It looks like you tried to open a RoboDK project file and you operated with it.
Can you provide us with the RDK file and the steps to reproduce the crash?
See attached rdk file.
.rdk   maching.rdk (Size: 2.56 MB / Downloads: 498)
Steps to crash are as follows:
RoboDK new station opened with the project.
Software waited 10min until crash.
I was under impression that it was opening a project caused the crash but that is not the case. I ran the debug without opening project and is attached below:
.txt   RoboDK.debug.txt (Size: 3.59 KB / Downloads: 513)
Any update on this?
It seems like another application is closing RoboDK. I was unable to reproduce this issue with the latest version of RoboDK.
I noticed you are using RoboDK v5.3.5. Can you try updating to the latest version?
The re-install solved the issue.
Many thanks
