08-15-2019, 01:46 AM
I was following these steps to set up the RoboDK driver for ABB robots at the following link.
https://robodk.com/doc/en/Robots-ABB-Rob...#DriverABB
1.Connect the computer to the robot using an Ethernet cable (or RS232 connection if you are planning to use serial connection). [For this, I used a service port of the ABB IRC5 controller to connect to my computer.]
2.Load the RDK_DriverSocket.mod module to the robot (using a USB drive, FTP transfer or RobotStudio). It should be used as the main task and this module already contains the Main program call. [This is where I have a problem. I do not know where to find 'RDK_DriverSocket.mod'.]
Would appreciate it very much if someone helps me with this.
Thanks and regards,
Win
Thanks and regards,
Win
