RoboDK plugin for Inventor 2024
Hi. Is the RoboDK plugin available for the latest version of Inventor 2024?
I followed the steps for manual instalation here (including copy pasting the dll file to a correct location), but the plugin does not appear in the available add-ins inside Inventor.
When installing the plugin the system console does not print 'Installing RoboDK plugin for Inventor 2024...' only 2019, 2020, 2021
Can you confirm if the following folder exists?
%APPDATA%\Autodesk\Inventor 2024\Addins\
Can you try running the BAT file in the package attached and let us know if it works?
We should simply copy the DLL and the Addin files in the Inventor Addins folder.
.zip   Plugin-Inventor.zip (Size: 248.02 KB / Downloads: 592)
(08-22-2023, 06:59 PM)Albert Wrote: Can you confirm if the following folder exists?
The file you provided did not work for Inventor 2024, but in my older version 2023 it does. Good enogh for me. Thanks for help.
Great, thanks for letting us know.
If you can tell us where the Inventor Addins folder is we can try to create an installer to deploy the files automatically for Autodesk Inventor.
Inventor 2025
\Program Files\Autodesk\Inventor 2025\Bin\Addins\
Follow these steps to install RoboDK for Inventor 2025 or Inventor 2024:
  1. Unzip the BAT file attached in this folder: C:/RoboDK/Other/Plugin-Inventor/
  2. Run the file as an administrator.
Let us know if running this BAT script as an administrator does not work as expected.
.zip   Plugin_Install_RunAsAdministrator.zip (Size: 655 bytes / Downloads: 426)
