12-04-2023, 02:06 PM
(This post was last modified: 12-04-2023, 02:10 PM by Li Chenglin.)
I found a problem that RoboDK robot panel TCP coordinate(Tool Frame with respect to Referencec Frame) is disagree with the TCP coordinate of UR robot contorller, even they do have same 6 joint angles in controller and robodk.
Please help to find out how to make the same coordinates computed by roboDK and those computed by UR controller.
Note:TCP in roboDK and controller both are with respect to UR5 robot base Frame
- use the same UR5 robot
- tcp coordinates in robodk and in controller are both with repsect to UR5 robot base Frame
- tcp has set the same values with UR robot controller(tcp:tool frame tool 1 with respect to robot flange)
- robot parameters have set same link lengths with UR controller.
- if I checked the "Use Controllers Kinematics" , then the TCP coordinate(Tool Frame with respect to Referencec Frame) will be totally same with controller tcp coordinate. But the the "Use Controllers Kinematics" only can be used for single-time (or static) computing, cannot real-time computing the tcp coordinate during draging robot tcp in roboDK station.
