RoboDk Add-in Siemens NX
I am wondering whether it is possible to make a RoboDK add-in in Siemens NX. The same one as the one available in SolidWorks and Siemens Solid Works. It would make creating parts in Siemens NX and using them afterwards in RoboDK much easier.
We requested a temporary license of Siemens SolidEdge 2024 and we are planning to make our SolidEdge plugin compatible with version 2024. We'll keep you posted.
(02-29-2024, 08:50 AM)Albert Wrote: We requested a temporary license of Siemens SolidEdge 2024 and we are planning to make our SolidEdge plugin compatible with version 2024. We'll keep you posted.
Will the add-in than also work in Siemens NX? Because I think Siemens Solid Edge and Siemens NX are two different programs and licenses.
Thank you in advance for the answer!
I'm sorry for the misunderstanding. We don't have an addin for Siemens NX but we can look into it. We need a contact from Siemens that can provide us with licenses for our development.
Could you send us an email through our contact form?
https://robodk.com/contact
Following up with your request, we just updated the RoboDK plugin for SolidEdge to make it work with SolidEdge 2024. You can download the latest version here:
https://robodk.com/files/upload/Plugin-S...eSDK24.zip
You should unzip the new Plugin-SolidEdge folder and follow the manual install procedure explained in this document:
https://robodk.com/doc/en/Plugin-SolidEd...ualInstall
Can you check it and let us know if you have any issues?
