If you download the data sheet for this robot, you can see the axis angles given. See attached pictures from the data sheet and RoboDK.
For axis 1, Clockwise rotation is positive, just like that in RoboDK and goes up to +185 degree and CCW goes up to -185 degree.
Hope this clears your doubt.
Hi Vineet,
thank you for your clarification
Following the axis assignment that Jeremy shared (which I have attached before) I was trying to understand why the actual rotation for joint 1/4/6 (simulation and real robot) is mad opposite to DH- parameter definition of roboDk, which I have access to as am using roboDK with professional license
Hello, has your problem been resolved? I recently encountered a similar issue while using the Robotics Toolbox. I built a 6-axis robot using the Robotics Toolbox, but the rotation directions of joints 1, 4, and 6 differed from those in RoboDK. Comparing it with the actual robot, RoboDK and the real scene were consistent.
