11-24-2021, 01:02 AM
Hello, I am using the trial version to check if my robot(Hyundai HH020) can use the Robodk program.
But, During the test, a problem occurred that the robot program was not created.
Problem:
When the robot program is created, the program is not created and the simulation is executed in RoboDk.
The expected problem is the length of the program. Because about 500 lines of program are generated. But, about 2000 lines of program should be generated. Is the number of lines of programming limited?
I tried changing the limit max line per program option in Robodk program and limit max line per program in post processor python code for that robot, but it didn't work.
I'd appreciate it if you could let me know what's wrong and how I can fix it.
Thank you
Problem:
Thank you
