10-24-2022, 01:48 AM
Hello, I am trying to develop a system where I can roundover a piece with a certain degree of flexibility in placement. The piece in the file provided is not the actual piece I will be cutting, I am simply using it to learn if this is possible in roboDK. The way I am doing this is having the spindle on the cutter further out, and pressurized against the edge of the piece. In order to accomplish this, and my reason for posting this, is I need to keep the spindle relative to the curve. I saw you guys had a "robot holds object and follows path" option. But when I try to utilize this feature, it seems to move the entire toolpath operation with the robot, which I found rather odd. Is something I am missing? I have a test reference frame tool in the station, that I would like to move perpendicular to the tangent line of the curve of the toolpath.
Thank you!
roundoverproject.rdk (Size: 1.17 MB / Downloads: 650)
Thank you!
