08-18-2021, 02:08 PM
Yes, the modifications are important.
In the approach and retract movement, instead of making it 0 mm, you should use the "-" sign to remove the app or retract all together.
If you "right-click"->"show instruction" RDK will consider you potentially made modifications to your program. To avoid overwritting any mod of yours, if you press "update" again in the Robot Machining Program with new parameters, it will create a new version of the program at the bottom of your station tree.
