Hi Sit,
How to use the API to perform the Save Stl function,
As attached image(Test0001.png)
thanks
thanks
Save as STL using the API |
Hi Sit,
How to use the API to perform the Save Stl function, As attached image(Test0001.png) thanks
06-02-2024, 07:51 PM
You can save your objects as STL files using the API by using the Save command:
Code: object_item = RDK.Item("Object", Robolink.ITEM_TYPE_OBJECT)https://robodk.com/doc/en/PythonAPI/robo...olink.Save |
| 1 Guest(s) |
