Set general acceleration on Program events window
Working with programs (.nc), I always need to 'Show Instructions' and change ACC/DEC in one of the set speed instructions.
I would _VERY_ much like to have a option on the 'Program Event' window where I can set this together with the 'Rounding' setting.
I'll also report the bug where motoman yaskawa robots do not support setting ACC/DEC _AND_ PL on the same line. You can only have one of them, acc/dec or PL.
I would recommend you to create a custom script or add-in to change the set speed instruction to specify the acceleration settings. This could be as simple as this:
from robodk.robolink import *  # API to communicate with RoboDK
import json
# Start the RoboDK API
RDK = Robolink()
# Ask the user to select a program:
prog = RDK.ItemUserPick("Select a Program to modify", ITEM_TYPE_PROGRAM)
if not prog.Valid():
    print("Operation cancelled or no programs available")
    quit()
# Ask the user to enter a function call that will be added after each movement:
print("Program selected: " + prog.Name())
# Iterate for all instructions (index start is 0, you can also use -1 for the last instruction)
ins_count = prog.InstructionCount()
for ins_id in range(ins_count):
    # Get specific data related to an instruction
    # This operation always retuns a dict (json)
    instruction_dict = prog.setParam(ins_id)
    # Print instruction data
    #indented_values = json.dumps(instruction_dict, indent=4)
    print("\nInstruction: " + str(ins_id))
    print(instruction_dict)
    # {'Accel': 3000, 'AccelSet': 0, 'JointAccel': 800, 'JointAccelSet': 0, 'JointSpeed': 500, 'JointSpeedSet': 0, 'Name': 'Set speed (100.0 mm/s)', 'Speed': 100, 'SpeedSet': 1, 'Type': 2}
    # Note: The type is unique for each instruction and can't be changed.
    #    However, setting the Type value to -1 will delete the instruction (same as InstructionDelete())
    if instruction_dict['Type'] == INS_TYPE_CHANGESPEED:
        # Set accelerations:
        newvalues = {}
        # Set joint acceleration:
        newvalues['JointAccelSet'] = 1
        newvalues['JointAccel'] = 50
        # Set linear acceleration:
        newvalues['AccelSet'] = 1
        newvalues['Accel'] = 40
        # Update instruction data
        prog.setParam(ins_id, newvalues)
        break
This is based on this example:
https://robodk.com/doc/en/PythonAPI/exam...structions
In short, each instruction can be represented as a dictionary with custom parameters.
Thank you for letting us know about the bug. We'll fix this with the next update.
Thanks for the script! worked perfect
Great, thank you for your feedback.
