Threads: 9
0
08-03-2022, 04:34 PM
Hello, I am attempting the setup the maketp.exe file, but it is asking me to run setrobot.exe first. When I select run as administrator, a command prompt flickers, but nothing else happens. Do I need to create a cell first? I am quite confused.
Thank you,
Jeremiah~ Robotics Developer
Threads: 2
226
Yes, you should first create a Roboguide cell, save it and run this setrobot command. Make sure to create a cell with a robot having the same number of axes.
Make sure to include the correct number of external axes if you have any.
Once you have a Roboguide cell saved you'll then be able to select that cell with setrobot.
