Simulation Events API
Hello everyone, I'm working on a c++ plugin for RoboDK and I'm wondering if I can call simulation events using APIs somehow. In particular, I need to add an "attach to tool" and a "set absolute position" event instruction to a program.
As far as the attach to tool event is concerned, is there a way to choose the object from a list rather than picking the closest one?
I guess some kind of JSON/String is required, in case would you please show me the format needed?
Thanks a lot in advance, have a good one!
To trigger these type of events it is better to use custom Python scripts.
For example, you can add a custom Program call instruction to a Python script using setParam and a JSON string as shown in this example:
https://robodk.com/doc/en/PythonAPI/exam...structions
This works in C++ the same way.
Then, in your Python script you can use setParentStatic to change the relationship of a specific object.
