Skip DI wait automatically when running simulation
I have a program that i transfer to the robot and i has a few "Wait_DI()" calls for syncing with the gripper etc. These waits are not needed in the simulation.
Is there a way to automatically skip these waits when running the simulation so i don't have to manually right click them and press "Skip DI Wait" for every cycle of the program?
Attached Files Image(s)
It is not possible to automatically skip these waits for digital input states. However, you could have a script running that automatically sets the corresponding station parameter to skip the wait.
Example:
while True:
    RDK.setParam("enable_actuator", 0)
    time.sleep(0.1)
Thank you i didn't think about adding a thread for this.
i ended up just creating a program via the gui rather than a python script since it's cleaner. The program just has two instructions that is "insert code -> enanble_actuator = 0" and a wait instruction for 100ms. Run the program on a loop and it all works out.
Thank's again for the help
Perfect! That makes sense, I didn't think it would be easier to make this program running in a loop using the UI. Thank you for your feedback.
