RoboDK Add-in for Solid Edge 2024
Looks like the RoboDK Add-in is not compatible with Solid Edge 2024. I had to remove the Add-In to successfully run SE2024, and can't seem to reload the Add-in.
SE2024 crash's immediately entering any modeling environment with Add-in installed.
I have same problem. How can it be solved?
(02-08-2024, 07:14 AM)Anatolii Wrote: I have same problem. How can it be solved?
I contacted RoboDK directly, and they were going to look into it. But haven't followed up with them. Currently, i deleted the add on completely and am running without it.
We test RobodKD 5.7 with the Solid Edge 2024 now, and we get same error henceforward.
Will be repair it in the immediate future? I attached the Solid Egde error logs, and a video from the error.
If you need any more information we try to help.
Tibi
.zip   SolidEdge.zip (Size: 2.94 MB / Downloads: 372)
We just updated the RoboDK plugin for SolidEdge to make it work with SolidEdge 2024. You can download the latest version here:
https://robodk.com/files/upload/Plugin-S...eSDK24.zip
You should unzip the new Plugin-SolidEdge folder and follow the manual install procedure explained in this document:
https://robodk.com/doc/en/Plugin-SolidEd...ualInstall
Can you check it and let us know if you have any issues?
.zip   Plugin-SolidEdgeSDK24.zip (Size: 501.74 KB / Downloads: 349)
It seems to be working! Thank you. If i run into any issues i will let you know.
Great, thank you for your feedback!
