SolveIK sometimes causes robot to rotate in weird orientations
Why is it that when I sometimes use SolveIK even with a provided joint reference the robot will try to do weird joint movements just to get to position?
The positions I would want the robot to move to are in front of it with the 6th joint being the only one needing to rotate the whole -360 to 360 range.
Original joints
Joints after applying solveik
I've attached an example rdk with all the positions I want the robot to move towards from solveik
.rdk   ur10_hec_station.rdk (Size: 2.79 MB / Downloads: 128)
One way to obtain the joint values that are closer to the current location is to provide the current robot joints to the SolveIK function.
Example:
joints = robot.SolveIK(pose_base_to_flange, robot.Joints())
Another option is to use the SolveIK_All function to obtain all possible solutions and filter for your preferred option.
https://robodk.com/doc/en/PythonAPI/robo...em.SolveIK
