Start program from py script
Hi All,
We try to start a program in the tree from a python script wich is triggerd externaly.
External trigger is working ok.
But the command to start a program is not working.
Any idea how to code that in there?
Thanks.
What do you mean by the command to start a program is not working?
You should be able to call RunProgram and the program will start (simulation):
program.RunProgram()
Also, if you want to run the program directly on the real robot using the run on robot option you can do:
program.setRunType(PROGRAM_RUN_ON_ROBOT)
Thanks it works!.
Rick
