08-09-2022, 03:59 PM
How are the values in the Set Speed instruction used by RoboDK to determine the simulation time?
The units of the Set Speed values can't be specified: they can be absolute in mm/s, deg/s, or relative as a percentage. Whatever values are entered will show up in a speed command as-is when exported to a robot program, so they should simply be entered in the units according to the command definition of the applicable robot; that's fine. In my case of a Mecademic R500, a percentage is to be entered for all linear and joint speed and acceleration commands.
To determine the (absolute) time simulation of the robot performing a certain movement though, I think RoboDK must somehow relate the Set Speed values to absolute units such as deg/s. How else can you get a time simulation shown on screen in absolute time units?
I would like to know how the speed values are interpreted and used by RoboDK to derive its time simulation.
Maarten
Maarten
