UNABLE TO CONNECT TO AT960 LASER TRACKER - IP
(This has the same title as an old thread, but it's a separate issue.)
When I try to connect to a Leica AT960 laser tracker, I get the following message:
Working...
Working...
Connecting to tracker: TRACKER_IP_ADDRESS
Working...
IP Address: TRACKER_IP_ADDRESS
Error# 38
No Tracker connected
Tracker not recognized (cable connection problem?)
at LMF.Tracker.Connection.Connect(String connectionString)
Tracker error
Unexpected error: File "C:/RoboDK/api/Leica/LeicaTrackerPilot.py", line 206, in RunDriver
Unexpected error: RunCommand(LISTCMD.pop(0))
Unexpected error: File "C:/RoboDK/api/Leica/LeicaTrackerPilot.py", line 280, in RunCommand
Unexpected error: if TrackerConnect():
Unexpected error: File "C:/RoboDK/api/Leica/LeicaTrackerPilot.py", line 501, in TrackerConnect
Unexpected error: return ConnectToTracker(Tracker_IP)
Unexpected error: File "C:/RoboDK/api/Leica/LeicaTrackerPilot.py", line 686, in ConnectToTracker
Unexpected error: connectedTracker = Connection().Connect(ipAddress)
Unexpected error: LMF.Tracker.ErrorHandling.LmfException: Error# 38
Unexpected error: No Tracker connected
Unexpected error: Tracker not recognized (cable connection problem?)
Unexpected error:
Unexpected error: at LMF.Tracker.Connection.Connect(String connectionString)
I am able to ping the tracker.
Is there a workaround for this?
Python version: 3.7.3
Pythonnet version: 2.5.2
RoboDK version: 5.5.2
It looks like you didn't enter the IP of your Leica laser tracker properly. Can you send us a print screen of the laser tracker connection settings?
Hi Albert, I came in this morning and it just started working... Kind of bummed I can't reproduce this anymore.
I will mark this as resolved and reopen if I can reproduce the issue again.
